I purchased a used boat that came with two Hummingbird Wide Eye T depth finders. As luck has it, they dont work when I put them in the holders, I realize they are maybe late 90's model so I'm not upset.
My question is about determining what to replace. I have two in the 14' boat and the wiring/base are well routed and attached.
Can I use the same wiring, bases and sensors for new equipment, if I stick with Humingbird? If not will it be possible to use the same wiring or should I just replace everything?
Cost is an issue and currently not alot of time for fishing, what is the best entry model?
Thanks in advance.
Thanks in advance.
