Tripp Halbert
- Joined
- Jul 30, 2013
- 202
Hello all. I am trying to track down a bad leak in my 1995 mercury 115's lower unit. I replaced the whole water pump system. Ran it on hose, still got water in it. Drained it and rreinstalled plugs. Dropped it in a wheel barrel of water, no bubbles except coming abruptly through The Outlet Of The Water Pump Housing (I Assume This Is Normal Since That Has To Fill with water so bubble show initially??)
Some things I noticed that I'm not sure are normal:
The prop area fills with water coming through as I drop the whole unit in, prop first. I wondered if water gets that far would it go into the gear housing??
residue near water pump house where it has a runoff into the exhaust area.
I have no gear oil coming out of prop, just black exhaust.
After I pulled the unit out of barrel, I pulled the gear plug and more watery fluid ran out. Seems like it's taking a lot of water but how could it be the prop if there's no fluid coming out of it?? I tried to look for fishing line but prop is stuck on shaft as of now
Thanks for looking, any advice is appreciated!
