Hustler 4 blade?
Sea Ray Joe
Any one have experience with this prop?
I would like to know if you had to go down in pitch to allow for the 4th blade.
Thanks
Joe.
steelespike
Re: Hustler 4 blade?
Without your present prop size,max rpm and speed its difficult to know the best for your application. Yes sometime they suggest dropping one inch in pitch but it all depends on your present performance.
Sea Ray Joe
My boat uses a stock 19" 3 blade.
Normally I find a 4 blade prop will be in 1" smaller increments but the Hustler is in the same increments as a standard 3 blade so this is why I asked the question.
Should I look at the 19" 4 blade or the 17" 4 blade.
Just looking for what others had to do with this prop.
Thanks
Joe.
