hwsiii
- Joined
- Jan 25, 2009
- 2,639
It seems there are many questions asked about Hydrafoils and Trim Tabs on a regular basis, so I tried to compare the two with each other.
There are tremendous amounts of Hydrafoils sold every year under different brand names, they serve a purpose or they couldn't sell them in those amounts. Some of the reasons people buy them is to try to raise the stern of the boat up to improve hole shot performance and to keep the bow down during takeoff to planing speed and/or to help carry heavier loads in boats that are either underpowered or have the wrong prop installed.
For small slow boats they do work very good and are usually about $ 50 to $ 70, but you an buy Smart Tabs SX for very little more money and they are much more efficient and can actually increase speed as well as help keep the boat balanced fore to aft as well as port to starboard, and a hydrafoil does not do this because it is in the center of the boat and thus does not help balance the boat from starboard to port.
To use a hydrafoil and not have problems the outboard needs to be mounted so the hydrafoil is actually out of the water at cruising speeds and in most cases smaller boats are not setup this way but since they are slow it doesn't usually matter as it does help pick the stern of the boat up. But in larger faster outboards when it is trimmed up for maximum speed and the motor is not mounted high enough on the transom the hydrafoil actually adds excess drag and slows a faster boat down. The hydrafoil can also trip on itself in higher speed turns and certain wave action directions as well as it can and does increase chine walking on very fast boats, whereas trim tabs help reduce chine walking and the bad behavior of port to starboard listing.
Stern drive boats usually should never use hydrafoils, because the anti ventilation plate never rides out of the water and is always immersed so they will in most cases create more drag at high speeds and actually slow the boat down at higher speeds. Whereas with either smart tabs or trim tabs, if they are set in the right position, only lift the stern of the boat and create nominal drag or can actually help a boat attain higher speeds than before their installation.
With a drawing of Trim Tabs versus Hydrafoils you can see very easily why trim tabs are much better in most cases, because you can tell that the stern is being held up at the outer chine areas of the boat and NOT the center, which makes the boat more prone to leaning either to the port or starboard like a seesaw.
Trim Tabs and Hydrafoils
Hydrafoil
In this picture you can see why a hydrafoil that is not mounted high enough on the transom creates extra drag and can actually slow a faster boat down because it is not on top of the water but in the water flow.
Trim Tabs
Whereas with Trim Tabs you can see they do not create this extra drag unless they are deployed deep in the water column to either plane at very slow speeds or to push the bow of the boat down so the boat an cut the waves with the bow instead of hitting the boat further back than the bow and causing it to slam and have a bad ride in head on seas. A hydrafoil can possibly do this also with the engine trimmed all of the way down, but that means it can't be out of the water and it is creating extra drag on the boat at all times and slowing it down.
Advantages and Disadvantages
H
Hydrafoil
Trim Tabs
H
