Hydraulic brake question
zell66
Until last year never had a boat with Hydraulic brakes. After sitting for winter took boat out last weekend. While I was driving to landing to bring boat out of water the driver side rear axle locked up. I stopped put into reverse for 6" or so and then forward and worked fine. Boat dealer says could be just rust but how does one check this type of system?
Watermann
You may need to replace the wheel cylinders and or the actuator in the coupler. Only way to know is to tear it down and see how things look.
