sogood
- Joined
- May 11, 2016
- 361
As part of an overhaul of my outdrive, I'm replacing the gimble housing on my Alpha 1 Gen 1. I have to dismantle and use some parts from the original outdrive and I've run into a bit of a problem. Can anyone tell me how the hydraulic hoses assembly can be removed, where they join together in a sort of "block" connector which is located under an anode (I think) just next to/between the rams. Hope I'm explaining properly but I've included a picture that might help. The tan and black hydraulic lines connect to this block but the point of connection is inaccessible, so how do I remove the lines?
Thanks in advance.
PS. I accept that the general assembly is in a sorry looking state. This is part of the reason/problem which I inherited when I bought the boat, but rest assured it's all being put right!
Thanks in advance.
