hydraulic steering install
tim24
Hello im looking at installing a hydraulic steering system in my bayliner trophy 5.7 with a290 dp is there a place I can find installation instructions how and where to mount and connect the ram ?
Ayuh,..... Each system varies, so that info would come from the maker of whatever system you decide on,......
Assuming your installing the standard VP hydraulic steering, and not full hydraulic like what is found on performance boats, the cylinder attaches to the transom plate. Would be attached to the 2 bolt pins see in top left of pic
tim24
Thank you I want a helm actuated hydraulic system no cables no engine mounted pump Thank you again for time
Then Bondo has the answer. Go to the place where your buying the system and they should have instructions. If your unable to find them, let us know what system and we maybe able to assist
