Hydraulic Steering Question
robayles
I have a Seastar hydaulic steering system on a 1999 Wellcraft 210 Sportsman that I recently purchased. How often should I check the helm filling station to see if fluid is present? If no fluid can be seen can I just add fluid till it reaches the tread lines or do I have to bleed the system?<br /><br />The Big O
Solittle
Re: Hydraulic Steering Question
I check mine every time out and top off as necessary. There is no need to bleed the system if there is no air in the lines.<br /><br />I have come close to being 5 miles out with two good running motors and on the edge of loosing my steering due to low fluid. Perhaps now I overdue it a bit. On the other hand is is one less thing to think about if checked before you head out.
robayles
Thanks for your advice. I'll get in the habit of checking it before I head out each time.<br /><br />The Big O
