Re: Hydraulic Steering ??
How do I know if I have hydraulic steering on my boat? I have 2 steering cables, Is hydraulic like power steering on a car, is there a power steering pump? The steering on my boat is real stiff, but I haven't had it in the water yet and will it be easier in the water?
Thanks
Joe
If you have cables, you do not have hydraulic steering.
Hydraulic steering is not like power steering on a car; the pump is called the helm pump, it is operated by turning the wheel. Hydraulic steering is much smoother and easier than cable steering, but unless it is hooked up to a power steering pump (usually on an inboard large vessel) the pump action comes from the helm.
If the steering on the boat is stiff and it is not in the water, then it will be MUCH stiffer when you are in the water and have the motor pushing against you. The motor should move freely when it is on the trailer. Sounds like you have something in the cable or steering system binding; you need to fix this or you could be in some trouble when on the water.
I just recently added hydraulic steering to my boat, what a huge difference; if you have the ability to make the upgrade, I highly recommend it!
