hydraulic tilt need hydraulic oil or 10-30?
Don S
Re: hydraulic tilt need hydraulic oil or 10-30?
What are you tilting? OMC, Mercruiser, Volvo? ? ? ? ?
sting1
hi, it is mercruiser 160 hp, 1967, straight 6, can we use 10w30, in a pinch?
hows ketchikan,,we were then on cruise in may was nice place. k
Scaaty
You can use 30w NON-Detergent.. few bucks at WalMart
Actually,.......You can use about Anything in a can that says "Oil"........
ATF,......
P/Steering fluid,.......
Hyd. oil,......
Engine oil,......
About Anything up to a 50W Will Work,.....
But,.....
The lower the W # the Better the pump will Like it..........
Don S
Not only can it be used in a pinch, 10w30 is what is recommended in the Merc service manual.
