Hydraulic tilt trim fluid
rajawolf
Mariner around 1983 - 85....external pump in boat..manual says to use a brand name 10w-30 or a 10w-40 automotive oil...the oil in mine looks more like power steering fluid or auto trans fluid red in colour like wine....what do i use? as the manual has confused me.<br /><br />thanxs
Trent
Re: Hydraulic tilt trim fluid
Use Dextron III transmission fluid.
rajawolf
Thank you Trent for the reply.<br /><br />Cheers mate<br />Tony
Ben Konopacky
TRENT ; WHY Dextron III ? If manual reads 10W-30/40 automotive oil. Am I missing something ???
TLL
Since you have a remote mounted pump,10-30,10-40, or 30W are all acceptable oils for your TNT unit. Someone put the wrong fluid in. It likely won't hurt anyting, but eventually could cause leaks.<br />TNT Units mounted between the transom brackets with integral pumps use Dextron/Mercon ATF.<br /><br />Todd
KCLOST
Yep 30W fluid is what mine had in it...
ZmOz
If yours is already red somebody else probably already used transmission fluid. Does it smell like transmission fluid? If that's what is already in there, then you should continue using it. Mixing ATF and oil probably wouldn't be very good.
