Hydraulic trim oil in bilge
Status
Not open for further replies.
warfrik
My drive was stuck in the up position at one point. I had someone push the drive down while im pressung the down switch. I finally went down. Its working now and i lubed the hydraulic rim shaft. Now its working up and down no problem, except i found some trim oil in the bildge, i think its when my buddy push the drive down that caused it.
Now, i cleaned the bilge, trimmed the drive up and down a few times, no more oil.
When i cleaned the boat after i used it the last time, there was no oil, and i didnt run the boat. Only thing i did to attempt to trim the drive up and down.
My question is, is there a release valve that releases too much oil under too much pressure? There is no evidence of oil leak coming from the pump or the lines coming from the pump. The only thing i cant see is the hoses under the y pipe ging to the transom.
Don't see how oil would winded up in the bilge from the trim pump and still be at the correct level.
bman440440
No Title
are you sure its trim/tilt and not power steering fluid? mercruiser states that you can use dextron(ATF) for the power steering and for trim and tilt... so you might want to check your power steering cooler lines... I have attached a pic of the cooler and lines to check
warfrik
The only thing i have not done is check the fluid level. My the oil in my tilt motor is engine oil. I loosened up the fitting at the outdrive some time and its the same color as the one i founs on the bilge. I doubt its my power steering lines. My atf is red in color
If its a bit low then that's where it came from. The trim pump uses 10w30
WhiskeyJim
I know this post is old but did you ever find the fix, I'm having a similar problem right now. Trim oil in my bilge along with some water.
GA_Boater
So why didn't you start a new thread? The guy with the leak hasn't returned so It's doubtful he will answer.
Closed.
Status
