hydraulic trim/tilt
sam-nou
Hello there anyone, I own 1991 Force 50HP it have hydraulic oil leaking from somewhere around the trim/tilt pump its leak when in use only I wonder if anyone know what it is or if can repairable I also have a lot of gas leaking from the bottom of carb. anything you can help I appreciate it.<br /><br />Sam Nou<br /> :eek:
JB
Re: hydraulic trim/tilt
Howdy, Sam.<br /><br />Welcome to iboats. :) <br /><br />Gonna move this to the Force Outboard Troubles forum.<br /><br />Good luck. :)
NordikWolf
check to make sure all fittings are tight. Also make sure the bleed scrw on the side is tight. the O-Ring mounted between the resevoir and the pump body may be shot or the 4 screws holding it worked themselves loose.
roscoe
As for the gas leak, probably time to replace the gas lines and rebuild the carbs, replacing all the old gaskets with new.
sam-nou
very help full Thanks a lot. I appreciate for your information. D:
sam-nou
Thank you so much for your help I show this msg to my friend neighbored who help me to fix the motor he follow your advised its work very good now. I really appreciated for your inform.
