Re: Hydraulick oil for tilt/ trim 1996 75 HP Merc
there is an oil specifically engineered for hydraulics. It is called "Hydraulic oil". It is what they use in the big multi-million dollar factories, mining operations, commercial fleet, etc. ATF, if you use the right type, is just as good in most recreational marine systems. ATF has about the same viscosity as ISO32 hydraulic oil. Hydraulic oil is the color of light honey. Hydraulic jack oil from autoparts is the same or similar to ISO32 but without the guarantees of precise formulation. Actual H.O. has additives to maximize the performance and lifespan of rubber seals while minimizing foam and absorbing transient moisture. You should never confuse DOT brake fluid with hydraulic oil. It will ruin your brakes and/or your trim if the two mix.
Some trim systems call for 10w, 20w, or 30w motor oil. You should never, ever use motor oil with additives. A better choice for these older systems (but extremely difficult to find) would be hydraulic fluid with a viscosity rating of iso64 or higher.
another variation on hydraulic oil is AW32 and tractor fluid. Tractor fluid is the HO equivalent to Dextron. It is a hydraulic oil engineered to be a decent enough ATF substitute. AW32 is an all weather oil engineered for use in a canadian winter. It is great for snowplows and such.
In my shop, i always reach for ISO32 first. I take pride in my work and want it to last as long as possible.
