First the particulars... 1987 GM Marine 350ci coupled to an AQ-275 Volvo outdrive. The original engine was replaced a couple of years ago with a new GM 350ci. At that time a closed cooling system was added to increase engine life. This was what was known as a "half-system" where the engine is freshwater cooled but the exhaust manifolds were raw-water cooled via the crank mounted seawater pump.<br /><br />Now the problem... De-winterized the engine a few weeks ago and started it up with no problems. Ran great in the yard on muffs. Took it down to the bay last week and took the boat for a sea trial. Ran great but noticed a little "surging" at idle rpms. Took it home and ran it again on the muffs for almost a hour to flush the exhaust and make some minor adjustments. Took it back down to the bay a few days later to test a new prop but engine would not start. It would barely crank over so my initial thought was dead batteries. <br /><br />Took the boat home and after testing the batteries, found that they were ok. Further investigation revealed that the engine was hydro-locked. Removed the plugs, cranked the engine, and water shot out of cylinders 3,4,5, and 6. These are the middle two cylinders on each bank. The water was clear and not green, so I know its not mixed with antifreeze. There does not appear to be any water in the oil. Antifreeze level in the closed cooling system seems to be normal and there is no volume increase in the oil pan.<br /><br />With these symptoms, I believe I can eliminate water ingestion through the intake manifold, heads, or block water-jacket. Agree? It also appears that the most likely culprit is the exhaust manifolds. I removed the exhaust manifolds and found some rust between the heads and the manifold gaskets (on both banks). This appears to be the source of the water ingestion.<br /><br />So my questions are... Would you agree or disagree with my diagnosis? Would you check any place else for for water ingestion? Is there any way to test the exhaust manifolds for leaks that would allow water to go back into the exhaust ports? <br /><br />Sorry for the really long post. I was thinking and diagnosing while I was typing. All comments are truly appreciated.<br />Thanks,<br />Andy
