Re: hydrofoil for my 73 115 hp Johnson
The only applications where tails don't slow you down are on flat bottom boats where you can set the antiventilation plate just above the bottom of the hull. That way they lift you out of the water then come out of the water on plane. The best options for holeshot improvement on your boat involves a lower pitch prop or a ventilated prop. Power trim is also great, but not much of a possibility for your motor or mine (which is of similar size and vintage). Trim tabs wouldn't help enough to justify the cost, but might be worthwhile if there are other considerations such as listing to one side or porpoising.
