Hydrofoil, what do u guys think?
Status
Not open for further replies.
basserfield
Got me a new SE Sport High Performance Hydrofoil today and taking it out on sat to test it out, whats the word on this unit, good or not so good?
Mi duckdown
Re: Hydrofoil, what do u guys think?
I guess you will tell us, when you come back from the test run.
Chris1956
what kind of boat are you using it on? Only need it on lumbering tail heavy boats, IMHO.
Lets see if that starts something.....
Fed up
I personally use one on my bass boat, I like it. I have tried the boat both with and without the foil on, and found that it plowed really bad with the foil off.
Now my boat is set up with dual tanks, and three batteries, all of which are located in the back of the boat and very little weight in the front of the boat.
TahoeQ4Pilot
I have the same one, on the SE sport clip since I didnt want to drill in to my lower unit. Actually its my second one, the first is at the bottom of my lake....it came loose one day and fell off. :eek:
It helps me with porpoising and more control at low speeds.
JB
I have gotten improved hole shot, low speed planing and no loss of WOT speed using SE SPORT 300s on my 17' Boston Whalers.
Do not just bolt it on and go boating. You will need to refine your setup as though you just mounted a new engine.
Good luck. :)
basserfield
It's going on a 1988 150 Mariner Magnum2. Thnx for the replies.
5150abf
Very polerizing subject that has been covered a couple hundred times here, kinda suprised noone has chimed in about smart tabs yet.
I run a homemade one on mine which is a copy of one I saw in Cabelas made from 3/16'' aluminum and it works really well but depends on the boat, some run better some run worse but as JB pointed out it is a different deal now and you will probably have to tinker with engine height and trim to see if it's really better or not.
I am on plane alot faster and can run lower speed on plane with, some say it puts stress on the engine mount but I have run mine for 9 years with no problems at all.
zippy83
i amnew to this Boat stuff. I have a 16' Lowe with 50HP mercury on. What will this stabilizer do in my case? Is it worth getting?
Uh oh, the thread police are going to get you for replying to a thread that's over 1 1/2 years old. :eek:
If you really want to open up this old can of worms start a new thread, then sit back and watch the fireworks. :D
Status
