Re: Hydrofoiles
A foil is not a bolt on and go type product, if that's how you use it, you won't get the best results and may get some negative ones and be disappointed. That's how many people use them though, bolt it on and head for the water, then report they don't work and are junk. The not working part is a lower top speed and possible handling issues, this is from the fin being in the water at speed. Putting on the foil "may" allow you to raise the motor, resulting in a higher top speed, better hole shot and improved mileage. This is not the same thing that tabs do, so the two shouldn't be considered as the same thing, although you may get "some" of the same end results with each product, they do it in a different way.
