I have a Hynautic K6 Steering Cylinder. I am attempting to replace the seals by removing the end caps/gland with a spanner wrench. The wrench is turning the end caps but they aren't loosening up. I read on another post about an access hole that you run a tool through to grab a keeper that holds a band/ring. I believe I have located these access holes and I think this tool came with the seal kit. I have tried to push the tool in the hole after rotating the cylinder but haven't had any luck.
I would appreciate help on how to remove these . Thanks,
Tom
Tom
