Re: I added more problems to my impeller change....
Couple of questions and we can figure this out, only three things can go wrong, one is the washer, no issue there. Did you remove the whole outdrive or just the gearhousing? First, place the control in forward position. Try to turn the prop. If it locks when you turn it CCW (looking from behind the boat) you are forward. If it locks CW you are in reverse. If you are in reverse and the control handle jams when you try to shift, the intermediate shift shaft is "off a spline". If it is in forward and the shifter moves freely back and forth, the most likely cause is the shift slider at the end of the cable has disengaged from the upper shift shaft lever. When you shift to reverse from forward the shift shaft should rotate CCW.
