Re: I already put this in repair
If you can reach around to the inside of the console then a fiberglass resin will fill in the holes pretty easily. Put a piece of fiberglass cloth on the inside and after it's set, just fill the holes with a resin kit.
If you can't reach the other side of the console, try using a automotive bondo mixed a little thick. "Smoosh" it in the holes, let it dry then sand it down.
