grizzreaper
- Joined
- Oct 8, 2007
- 160
This spring I took the bottom end off this motor. Put in reverse n could not get apart. With some tugging I ended up removing the shift lever. Then lost lever n pin. Found new locking pin n lever. After putting together I get forward, neutral but no reverse. Take back apart I push linkage down I get reverse. Pull up I get neutral n one more pull up I get forward. I assume clockwise is forward and counter clock wise is reverse. What am I doing wrong. Thanks in advance
