MotorBoatingMatt
- Joined
- May 23, 2011
- 15
Hi fellow boaters. I have 1968 18 HP Evinrude outboard model #18802A. mid 90s PSI on both cylinders. Water peeing strong. I bought this engine about a month ago, very clean inside and out ($360, good deal?). Guy said he inherited this outboard from a friend of his who had it sitting for years. When I looked at it he had it in the bucket of water and pulled it and it fired right up. Ran it a few minutes, turned it off, pulled it and started back up and ran no problem at all. About a month after I bought it I got it in a bucket (now that my boat is actually ready) and tried firing it up but I'm having some problems.
The engine will start and run for about 30 seconds and then slowly die. Sometimes I hear some nasty backfires from it too. I try pulling it over again...same thing. Sometimes when I just pull start it won't start but backfire and jerk quite abruptly. Then I can't get it to fire or do anything. If I wait a few hours the same thing will happen at the beginning of this paragraph. I read all the FAQs on awakening an outboard and carb cleaning, but this is what baffles me....if the carb needed cleaning (thats what I'm suspecting) how did this guy have it running so perfectly when I bought it? More info...
When I got the engine I put a 50:1 mix of TCW-3 engine oil mixed with regular gasoline. The guy told me he was running Omega 2-cycle oil through it and also put a bottle of sea foam in the gas tank. I haven't tried switching the oil and putting Seafoam in the engine YET, I was wondering if there are other things I should be worried about first. Or, if that will even make a difference. The guy said he never touched anything in the engine when he got it, which blows my mind away of how he had it running great when I bought it. Again, I'm not sure what could be wrong...I'm assuming carbs but I'm NEW to boating and in need of help! If carb does need cleaning, I couldn't find a kit anywhere online for this engine. Suggestions? Let me know what you guys think! Thanks!
