Re: I am dissapointed
John, I'll take a stab at starting that explanation. On the surface, the carb is different. A marine carb is designed to be more resistant to leaks and has vent tubes that drain overflow into the carb, instead of out of the card. The distributor, starter, and alternator are modified to prevent open sparks from igniting any fuel vapors in the engine compartment. The block will usually have brass freeze plugs instead of steel to prevent them from corroding out. The cam is also a "marine" grind which is much like an RV cam. The water pump will also have a stainless or brass impeller and slightly differend seals to fight corrosion, while many auto pumps use a steel impeller. The bolt on exhaust is much different as the manifolds have to be water cooled. Many of the gaskets are also of differnt material.<br /><br />There are other differnces that others will list, but these are some of the first that come to mind. <br /><br />That being said, many of the internal parts of my rebuilt V8 are "Street Race" spec auto parts like the pistons, oil pump, etc along with a cam of my choosing for the power I wanted. All bolt ons are marine. The carb, alternator, starter, distro, waterpump, etc are all marine approved.<br /><br />Hope this helps.
