I am going to upgrade my 2 piece rear main seal 5.7 to a newer 1 piece.
dan2744
I have the Gen 1 outdrive, will it mount to the newer coupler? I am already going to have to get a new flywheel starter and coupler, id like to keep the outdrive, is it possible, it sure looks the same?
Repowering with a newer block should not be an issue. What year is the original motor?
dan2744
1985, this one is a 90 s block with 1 PC seal. What flywheel do I need?
Assuming pre-vortec
If your old motor has a 12 3/5 flywheel, you will need to get a 14 inch flywheel and bell housing. Need the triangle coupler and offset starter
dan2744
That's what I was thinking just wasn't sure about flywheel, thanks. It is pre vortec.
dan2744
It looks the same, I know I need it for the mounts but I haven't pulled the motor yet
It does list the same part number clear through from what I found
