Re: I can really suck now...(clean)
I have to add my 2cents worth here!!<br /><br />I believe that the Rainbow vacuum is the best on the market, because no matter what vacuum you have or use, if it has a bag in it, all it is doing is throwing the garbage back out in the air!!! The Rainbow uses water as it's filter, and traps the dust and dirt in the pan for you to empty OUTSIDE the house, and doesn't store the germs in a nice dark warm bag to multiply while in the closet. Yep, ANY ANY ANY machine that you put away in the closet with a bag in it, shall multiply in germs while stored. And, what if you loan it out or use it in someone else's place? You got it, you pick up THEIR germs, or carry YOUR's to their place, and spread those germs all over...I pitted the Rainbow against EVERY vacuum on the market and it never lost (although Filter Queen was the hardest to compete against). If there is a bag or paper filter, it has holes in it. The holes get clogged in a few seconds, the AIR FLOW stops and the efficiency of the machine just went down teh tube. After that, all that happens is teh stuff gets beaten down into the carpet by the beater bar. I had several clients who got prescriptions for the Rainbow due to teh allergin factor, and got the insurance to buy their Rainbows as an AIR FILTER, because you can actually close a room, run the vacuum in it, and it will "wash" the air over a period of time.<br /> The Rainbow NEVER loses it's airflow because you cannot clog water, unless you pick up so much dirt it displaces the water, then you just change it out...<br /><br />The Rainbow is in teh same price range as teh Kirby, but for the money, I would NEVER buy a vacuum with a bag. My wife loves our Rainbow, and she has allergies worse than anyone I know! I cannot even mow the grass while she is home. She can walk into a two story house, and tell immediately if there is a guinea pig on the second floor, or if there is a bird in the house, even if it cannot be smelled, because it closes her sinuses right up.<br /><br />HOWEVER...as it has been said many many times, opinions are many and some stink...like a vacuum with a bag
<br /><br />A regular vacuum throws the dust right back into your face, and then settles back down on the furniture. Next time you vacuum, dust first, then come back about an hour after and see if the dust is back...
