MikeDobbs
- Joined
- May 8, 2015
- 205
Hi everyone- if you've been following my saga I believe I have got the electrical sorted out, and I've moved on to starting the engine. Bolted on the newly rebuilt carb today, and she turns over, and started to catch with a little starter fluid, but never fired all the way up.
(Mercruiser 3.0lx by the way)
I know the carb is supposed to pump gas with the throttle once there is pressure from the fuel line, but even after a fair amount of cranking and pumping of the throttle I could not hear any gas being pumped into the carb.
I suspect there is no gas making it's way to the carb. What should I do? I saw another post on the forum where someone recommended that the person prime the fuel pump, but I'm not sure how to do this.
Thanks in advance : )
