Re: I fear the answer
Can you be a little more specific as to what "knocking" sounds like? Is it metallic, metal to wood, is it low pitched, or high? Have you opened the engine compartment and listened with as little between you and the engine as possible? "knocking" can be just about anything. I would start with the engine and work my way back. Do you have a mechanics stethoscope or a really long screwdriver? If so listen to the side of the engine. If the noise sounds like it is from the inside then you have major problems. If the noise sounds like it "transmitted" to that point move more towards the rear until it get very distinct. I am thinking that worst case would be rod bearings at which point your boating season is probably over as you will need a new engine or atleast a good rebuild. Rod bearings kinda have a slapping sound to them and you should hear it fairly clearly even without the scope. It is sometimes hard to isolate noises on a engine because how well sound travels through the metal of the engine. Take your time, be patient and for God's sake be carefull around the engine while it is running. You would not believe how quickly you can get trapped in a moving belt. Do NOT wear any loose clothing that could get caught in it either. Be as specific with what the noise sounds like as you can (example: sounds like two spoons slapping together) and we will try to help you. I am pretty good with basic mechanics and know what quite a few sounds are, but I am sure that there are people on here that are better than I am. My expertise is more electrical/electronic and am adding hydraulics to that as well. Good luck and keep us posted.
