I feel North TX humidity help weaken my floor due to adding a window to monitor for water. With the window open for weeks knowing the floor was soft the wood never dried. When I siliconed a clear Lexan window inside the seat?s pedestal floor area, it fogged initially and later cleared some. My objective is to monitor for water under the floor that I have known of since 1985 before it weakened the floor. I could never find any signs of how the water was getting under the floor (using pressure and soap and observation for cracks). It appeared I got more water under the floor while out of the water tarped with the bilge plug pulled (vs. the floor?s plug that I feel was a mistake years later). I have built up above the soft floor with lexan plastic (expecting to get 2-3 more years from the 1968 15? Raycraft Boat).
The hull appears solid and tuff. I can only wonder if stringers were used in this design. At the window I cut I expected to find a stringer from what I could feel close but only found a good rigid pink foam sheet. I should have pushed a small rod through the foam searching for stringers but at that point I was an inch off the hull and felt the foam was all I would find. Last, I added 2 gallons of water (before siliconing and reinforcing the plastic). There was no signs of it in the window, due to the deep V in the center (with the boat level or tilted upwards as I store it tarped.
Please share some feedback! JOW
Boat's Floor .5 Lexan Plastic Reinforcing @ Weak Stand R.jpg64.2 KB · Views: 0 -
Bad Rear Boat Floor Lexan Window, silicone & Reinforced (8).JPG65.8 KB · Views: 0 -
Bad Rear Boat Floor Lexan Window, silicone & Reinforced (3).jpg143.9 KB · Views: 0 -
Bad Rear Boat Floor Lexan Window, silicone & Reinforced 2.jpg75.5 KB · Views: 0
