Reboot11133
- Joined
- Nov 11, 2007
- 74
1984 Force 85Hp
Well my piston is on its way so I decided to start preparing for the re and re. I am going to go in thru the reed ports as suggested by Frank. Anyway I kind of screwed up and removed the bolts that hold the reed valves in place when taking off the intake manifold. When I pulled each reed valve out of the engine I noticed what looked like big chunks of sponge inside the reed for the cylinder with the melted piston on the carb side. The foam baisically plugged up over 1/2 of the reeds. There were also some smaller pieces in one of the other reed valves but fortunately no damage to the other cylinder. From what I can figure out the foam came from the acoustic liner that use to be covering the inside of the top cover for the motor. There is only traces of it that are remaining where the glue attached it. I have no idea if this was a factory thing or a previous owners bright idea to make the motor quieter.
My carburetors have no cover over the throttle body to prevent this type of thing from happening. Was there a cover origionally? There are bolt holes so it could be installed...Hmmm maybe ebay?
