glennj3
- Joined
- Sep 6, 2011
- 381
Thanks Don for the help on the impeller.
I could not shift the shifter today, pulled the upper part of the outdrive off, found white oily stuff in the large bellows and the shifter cable was clogged up with a cream color hardened powder. Cleaned it all out, the shifter works smooth now but thinking about taking on the larger job of changing the bellows. Not sure where the water oil came from?
I understand I need a special star shaped device to remove the housing in order to get to the bellows, can I order that from this site or do I need to find one at my mechanics place?
I plan to order everything I need from this site so if you will list for me what all I may need.
One type of adhesive or two and where do I put it on the bellows?
Thanks again,
Glenn
Thanks again,
Glenn
