I purchased an 18' Sea Ray with a 200 Mercury outboard. There are two tanks, one up in the bow, one in the rear. Boat ran fine on the back tank, wouldn't run at all on the front.<br /><br />I drained the front tank. Built a valve to switch tanks using home depot purchased brass fitting and ball valves (designed for natural gas, propane, ect).<br /><br />It still didn't work.<br /><br />Then I saw what appeared to be a problem with the plumbing on my water/fuel seperator, so I reversed it. I believe this resulted in my pumping dirty water into my engine. Needless to say, I had a difficult time starting it in my driveway.<br /><br />I rebuilt the fuel pump. Replaced all the hoses. Installed a couple inline fuel filters (one before each tank and one after the primer buld before the engine). I also bought a new water filter kit and installed that.<br /><br />As of right now, I appear to have absolutely no suction to the front tank. There is absolutely no fuel moving from there. I pump the bulb hundreds of times and nothing happens.<br /><br />The back tank is running a little rough, but improving. I'm seeing some sediment in my last filter floating (maybe this is coming out of the engine?)<br /><br />I'm totally at a loss. I don't know what else to do? I even replaced the primer bulb moments ago, that did nothing.<br /><br />Come morning, I'll double check my cuts and connections in the line to ensure I'm not leaking air at them. But what else can I do? There's about a 20' of hose running from the engine to the front tank......<br /><br />Any help or ideas would be appreciated...<br />And, please take a look at my water filter question, so I can have some peace of mind when I crank the engine in the morning.
