LotsOfishinmyboat
- Joined
- May 1, 2011
- 8
anybody have any ideas on this problem I got?
at first it would not run at all unless the choke was pulled all the way out so I changed gas and ran some SEA FOAM carb cleaner threw it and it started running fine then I took it out to the lake and started great after just 2 pulls I started cruzing then tryed to give it some gas and it died. started it again and noticed that I had no prime in the ball primed it up and started fine again cruzed at low speed for a bit then tryed to give it gas again and died again.
I'm pulling my hair out as I just bought this motor I hope its something minor that I can fix if anybody has some suggestions it would be great
Thanks guys
T.J.
could it be sucking air/fuel starved
carb still dirty
clogged filter?
thanks again
Thanks guys
T.J.
carb still dirty
clogged filter?
thanks again
