Re: I HAVE A 1997 FORMULA. ENGINE HATCH LIFT MOTOR IS LOOSE ONLY ONE BOLT HOLDIN
1) You should repost this in the Boat Topics section and,<br /><br />2) You should try and post a picture. I have a hacth lift that in fact does mount to a bracket by a single pin. This single pin allows the ram to pivot as it raises and lowers. Required. But there is no way for me to understand if your system is similar. Good luck.
