i have a steering wheel is hard to trun
I have a 94 75 Yamaha 2 stroke I can steer the boat but for the most part its hard and at some points it pops like its skipping
Ayuh,.... Welcome Aboard,..... Is it well greased at the tilt tube at the motor,..??
It could be ya just need a new cable,.....
The skippin' feelin' is probably the worn out gears in the helm, from the bad cable, or lack of grease at the tilt tube,...
Is it a rotary helm, or rack, 'n pinion,..??
GA_Boater
Under the dash and out of sight behind where the steering wheel is attached, you will see either rack and pinion hardware
or a rotary system
Hope that helps some and welcome aboard.
