I have a trim pump problem. Need help.
m_sherman211
I have an 86 liberator. Everything worked last season great. Just de winterized boat yesterday and noticed that the outdrive will go down but will not go up. But when I push the trailer switch it raises the outdrive all the way. Any suggestions on what too do.
Family was hoping to go out on the boat this weekend.
dingdongs
Re: I have a trim pump problem. Need help.
maybe the solinoid gone bad.do you have one or two?anyway you will see a blue and a green wire which feeds the pump and these have to be supplied with 12v.
remember green for grass =down
blue for sky =up
if you get a 12 v jumper wire directly from battery briefly and touch onto the terminals one should make it go up and the other down.chance is you've lost supply and could be a wire in the sender to the drive broken also.if you have a multimeter you should be able to chase the fault.no magic cure only you can see what u have.
