First post - please be gentle and forgive any forum etiquette breaches !
Mariner 15hp Bigfoot 2005/6 - low hours
Me? - fairly mechanical - cars / bikes but new to outboards
End of last season started running uneven/ rough / stalling on idle - made manoeuvering (spelling ?)in a crowded marina difficult and very embarrassing !
so... routine engine service (New plugs, oil changes, fuel filter etc) no change
so.. assume its something to do with fuel
Drain & clean tank & new petrol
New hose & bulb
Strip carb, clean, ultrasonic jets
Still the same
But.... if I rev engine a little and put hand over air intake till engine almost stalls and then release, this seems to 'cure' the problem for a while but then its back again
(engine runs fine a higher revs)
so... is there still dirt in the system??
Clean carb again - still the same
as a last resort tried some Seafoam through the carb - still the same !
Please...
Hoping the collective wisdom of the forum may help me on this - want to get the boat back in the water but only when i can trust the motor
Any suggestions - even the most obvious! that i may have overlooked?
Thanks for your time
roger
New hose & bulb
Still the same
Please...
roger
