AuSable Junkie
- Joined
- Jun 14, 2009
- 29
The motor: 1969 Chrysler 55 h.p. model 5591.
Replaced all the seals on the lower unit, no more milky lube. I also fixed the twisted carburator bowl gasket, and the fuel no longer weeps from the top of the bowl. I thought this would cure my gas out of the weephole problem.
I still get gas running from the lower unit weephole when I pull her out of the water and let the motor down. I know its coming from the carburator. I see a gas drop clinging to the bottom of the open mouth just forward from the choke butterfly. Every time I run it, I see a gas "puddle" underneath the carb when it drips off the carb mouth and onto the the area underneath it. The gas makes its way to the motor leg and out the weephole.
I'd like to keep my motor from polluting the lake, is there a way to fix this??
