Justin_S987
- Joined
- Apr 5, 2024
- 12
Hello, I am new to here and new to boats as a whole but boating is something I have toyed with trying one day. So, out of the blue I came into possession of a free, but oddly, ok shape 1980 Renken... bowrider?? ...as close as I can tell but it has a solid deck on the bow. With an OMC 120 stringer outdrive. Story goes, a 69yo man was nearly finished rebuilding it in 2022ish and was holding off on reassembling it until he got a new set of ball gears. He finally just decided he was too old to work on it alone anymore and gave it to a couple I know until it sat in their yard 2 years and they gave it to me for free so they can move.
I have had this boat 2 weeks and gone down many rabbit hole researching it. I have since discovered that OMC anything is just a teensy bit outdated and complicated, but sounds doable and just up my alley and skillset. I plan to just take this boat out on rivers and lakes in the area and not push it too much.
From what I was told, the binder with the manual, along with handwritten notes, the boat is from Ohio, only ever ran in freshwater on the great lakes and some in SC. The boat has a new wood floor and transom that are coated in a black fiber coating and new carpet. It has a brand new full cabin canopy and everything attached to the hull is solid.
The engine is weathered but runs really well, has new coolant hoses, new fuel tank, fuel lines, filler tube and blower tube. No leaks or smoke. The engine didn't start at first and I traced it to the breaker contacts on the distributor being out of adjustment but it runs great afyer adjustment. So far I have only run it 2 minutes at a time and watched it with a temp gun since I can't run water through it yet.
The outdrive was already detached and it was easy to see that the hull side drive gear had severly worn out teeth. It appears the og owner had started to unwire some things at the dash like lights and radio but everything needed to start, run and steer is in working order.
Sorry to ramble on but...so far I have inspected the hull, transom, transom boot and floor for cracks and rot, I have found none but I also have not fully removed the carpet, so all I know for sure is the transom seems good there. I tidied up the engine and tested it. I found a new set of ball gears and seals on ebay and installed them and this coming week I plan to reattach the outdrive and test it.
At the moment I am curious about a few things. I found that engine had no or little oil in so I put 2 quarts in before testing (SAE 30), and the new coolant hoses dripped antifreeze before I tightened them up, so I assume that is winterizing and needs removed?
Next, both the ball gear housings had thick brown oil behind them. Is this seperate from the gearcase or will it get changed with a gear oil change? I bought 4qt of SAE 90 that says it is a direct substitue for 80w90 to change it with.
Finally, I am ordering marine grease for the drive hinges, tilt gear and steering gear but do I or should I apply grease to the ball gears as well?
