fishthebay
- Joined
- Aug 17, 2001
- 180
I should have never tried the easy out, but I did and it broke off.<br /><br />I have a 1987 85HP Force. While changing the lower unit oil this past weekend the drain plug was frozen solid, so I drilled through it and inserted the trusted easy out. (The drain plug is a small allen wrench style) Why Oh Why did they make um this way.<br /><br />Low and behold the thing broke off flush.<br /><br />To make a long story short I took the lower unit off and up to a machine shop that was open on Saturday. The machine shop was in the woods like out of the deliverence movie.<br /><br />Anyway the guy said it looked bad, but he gave it a shot. No drill bit would go through the easy out, so he punched it through and re-tapped.<br /><br />Anyway he said I need to get the broken off piece out with a magnet or something or it will screw up my gears.<br /><br />When I got home I flushed the lower unit out about 4 times with gear oil and I didn't find it anywhere in the bucket.<br /><br />I put the lower unit back on and spun the prop by hand in several different motor tilting positions. <br /><br />I didn't hear anything.<br /><br />I fired it up and put it in forward and reverse on the muffs and didn't hear anything abnormal at all.<br /><br />What should I do?<br /><br />I have not enough skill to take the gearcase apart and go fishing.<br /><br />The easy out was just the tip and a very small one at best.<br /><br />Will it just shred up if its in there and if I change the lower unit oil again after a run out to get the pieces out will I be OK?????
