I'm getting close to needing to purchase a gas tank before I can finish glassing my floor in.<br /><br />Originally, the boat had one HUGE metal tank in it. I think it was around 75 gallons, and weighed half as much as the boat!<br /><br />I'm thinking of going to two poly tanks instead of one big one. Reason being: 1 tank out, 1 tank back to dock. A built in safety measure.<br />Another reason would be that two tanks are better than one in case one failed (and I'm still alive
)<br /><br />Where can I get an 'off the shelf' poly tank? <br />It will need to be approx. 21" wide. The length doesn't matter, as I have approx. 7 to 8 feet to work with there.<br /><br />I don't necessarily need a poly tank. It can be aluminum. I definitely don't want steel again.<br /><br />I thought of making my own tank, but someone had mentioned the insurance issue.<br />I don't know what the problem would be, because if my home-made tank ever failed, I doubt I'd be alive to worry about it.
<br /><br />Anyone ever make their own aluminum tank? What grade/type of aluminum did you use?<br /><br />I have a full machine shop at my disposal. I work primarily in aluminum, so I have all the benders, welders, etc...<br /><br />Thanks in advance,<br /><br />H.
