I need feedback on Hill props
Status
Not open for further replies.
scbackpacker
Looking at a Signature Stainless Steel 4 Blade 21P prop made by Ron Hill. Anyone running a Hill prop? I would like to put it on my 4.3 liter Alpha 1 Gen2 19.5' Monterey hoping it will lift the stern better that my 3 blade.
walleyehed
Re: I need feedback on Hill props
When Ron himself was doing the building and testing I believe they had some top of the line props. The Business sold, Ron's son is producing the newer props and personally, I don't care for the recommendations they give. The only way you can replace a 21P 3-bld with a 21P 4-bld and get the same rpm and speed would be for 2 reasons...possibly the prop is a 20P as to turn the same rpm, but the speed won't come without being able to raise the drive to utilize the technology of a 4-bld prop.
If the drive cannot be raised, I'd expect a bit better hole-shot, good mid-range, but I can't see the speed going up if it was properly set-up with the 3-bld to begin with.
ArcadianStar
Hill Marine propellers are called Signature propellers. Speed comes from pitch, not number of blade. If you run a 21 three blade and if you don't want to lose speed, you should run a 21 four or five blade. Pitch is basically gears. Lower gears means lower speed.
Chad Hill has been making propellers since 1997. His father still builds about 1,200 performance propellers a year. They are partners in Hill Marine.
Chad Hill has recently developed four blade propellers for the Mercrusier Bravo III and the Volvo Dual prop. The word on the street is that these props are four miles per hour faster than the OEM three blade.
Chad has stopped racing, after 24 years, to devote full time to his propeller making business.
wca_tim
flip a coin... it's hit and miss.
walleyehed
"If you run a 21 three blade and if you don't want to lose speed, you should run a 21 four or five blade. Pitch is basically gears. Lower gears means lower speed."
This would only work if you can raise the drive or raise the HP.
This is where most folks end-up lugging an engine and causing premature failure of other parts.
This is the part of "signature" I don't like....they are not "Hill" props anymore, and the only props Ron builds are custom only, and when I talked with him last year he was building about 50 a year.
If someone wants to try one, have at it, but don't be disappointed when the rpm drops and no speed is gained....this is one reason I don't include any "Hill" props in any of my posted data. They cannot duplicate an exact match if a replacement is needed. I still have 2 of the same pitch, in fact same P/N and both give different numbers-too far off to be a "tolerance".
ArcadianStar
I am confused here! You talked to Ron Hill and he said he makes 50 props a year? That is interesting, I was at Hill Marine home of Signature Propellers, yesterday and they had more than 100 V-Drive propellers in stock. I'll stop by again and take some pictures of some of RON's props and Hill Marine's props.
I guess we don't see eye to eye on pitch, but that is OK I guess, you are the "EXPERT" here.
Ron Hill is prop19 on E-Bay, check he feedback rating.
wca_tim
Everyone I know that has tried hill props says the same thing.. if you get a good one keep it, but you've got just as good a chance getting one that won't run well. Sooo don't buy a used one, chances are it's not going to be a good performer. Just my experience and that of others I know.
There's a ton more to propping than pitch... and there is a bit of art to it - some props work better with some hull characteristics, etc... and there are a lot of ways to modify set up that will impact your result with a given prop. It's just not a simple thing. that being said, there are rules of thumb. Wallyhead knows his stuff, as do some others on here.
To consider a prop like a gear is a very good way to get in the right ballpark when starting from scratch, but in reality many factors come into play... angle of attack, pitch, diameter, rake, the progressive pitch profile (pitch changes along the blade of the prop - the "pitch" number is more of an average or apparent pitch... cup or lack there of in the blade, etc...
hwsiii
Arcadian, I really don't know that much about Ron's props, as I have never had one. But I can tell you that Kenny (Walleyehed) has forgotten more about props than you will ever know.
Your statement about the number of blades doesn't matter and just stay with the same pitch no matter how many blades the prop has or you will lose speed, tells me EVERYTHING I need to know about your expertise in propellers.
I doubt very seriously I will ever come to you for your EXPERT prop advice in this century. :confused:
H
scbackpacker
I was looking at the Hill prop on fleabay and was wondering what kind of quality props Hill makes. I've already gotten Hwsiii's advice on a 4 blade 21 pitch prop. I really wanted a SS prop but I've gotten better at controlling the trim on my boat and the 3 blade is doing good. My kids were going to get me a new prop for Christmas but what I've decided to do is have them take what money they were going to use to buy me my Christmas gifts with and help a lady out who is in foreclosure on her house and her kids have a good Christmas. She has a teenage son who just turned 18 and cannot find a job and a younger son I think around 12. I have all I need (well I could use a few more pair of boxers) and I would get more joy for Christmas to help them out.
captkevin
Know 2 people who purchased Hill 4 blade props & both were very happy with them. Would consider one for my boat. Wasn't aware of any quality problems.
Rocky_Road
Nice move...and good luck on the "boxers"!
Happy boating...and Merry Christmas! ;)
walleyehed
Maybe you misunderstood me...
Signature is the "new" name with new owners....Ron does not own this business anymore but corp. decided it best to keep the hill name for obvious reasons.
When I talked with Ron, he said he was building about 50 a yr-CUSTOM ONLY-Ron, not Hill Marine or Signature, of which may verywell build 100's of props a year. I know 4 manufacturers who build 100's a day.
A custom prop CANNOT be easily duplicated if serious damage would occure.
As for the "EXPERT" remark, I am not.....I prefer "Experienced"....to what level would be your determination if you happened to follow my advice.
We don't need to see eye to eye to remain respectful of each other.
642mx
H
Wow... instead of being a jerk and poking fun at the guy, why don't you try to help and post something constructive. Or just don't post at all!
642mx
I've heard nothing but good things about the Hill props. I almost bought one myself to try, but 3 blades seem to be the fastest props on Baja's hulls.
hwsiii
MX, 99% of what I post on here is constructive and helpful to people. I do everything I have the time for, to impart knowledge and a better understanding of props to people who have not acquired that knowledge yet, just look at my posts, and I already gave packer my recommendation for a better prop for his boat.
But I will not stand by and watch Arcadian try to denigrate Walleyehed and act like Kenny is wrong and he is right, beause that definitely is NOT the case.
H
scbackpacker
I'd like to say thank you again Hwsiii for the help on the right prop and come next spring there will be a Solas 4 blade 21 p prop on my boat.
ArcadianStar
H
hwsiii what is your background in propellers? How many propellers have you manufactured? How many boat races have you won?
I have won more than 25 Amercian Power Boat Association National awards, and feel you might be wrong on you positions about propellers.
While I'm at it, what are Wallyedhed's qualifications?
I just returned from the Miami Boat Show where Signature Porpellers had their new Four by Four Propellers for Mercrusier, Volvo and Yanmar Diesel. Their props had more blades than Mercury, Solas, Turbo or Michigan. Their booth had tons of interest.
Seems number a blades might be good, especially if there are more blades.
Seems Chad Hill is President and CEO of SIGNATURE PROPELLERS. Chad is Ron Hill's son. Chad went to his first boat race when he was a week old, and has raced boats since he was 9. He is 32 now. He was the youngest Formula One Outboard racer in the history of the sport. At 19, 1997, he was Formula Rookie of the year driving for Arcadian Motor Sports. (Those big ORANGE tunnel Boats powered by Mercury S-3000's).
Read about Chad at www.hillmarine.com or www.signaturepropellers.com
ADD:
There was a time that people thought RACE PROPS had to have two blades. Most Race Props today have Four or five blades.
hwsiii
I thought this discussion was over, but since you chose to bring it back up and question me about my statement:
I would have to say that from the Quotes reiterated above that we would have to agree that prop geometry matters more in most cases than the stated pitch of a prop.
I do my best to get along with everybody, but just because people have disagreements doesn't mean that they can't respect each other.
I believe this is all that we disagree on, and this is all I need to say, and i don't need all the statements that I had replied with earlier.
H
ArcadianStar
At Hinton, West Virginia 1976, there were 700 entries at the Kneeldown Nationals. Vern Kargus had the only three blade propeller there and he won his class of about 22 boats. On my way home from Hinton I stopped at the OPC Nationals in Dayton. I was helping the only kneeldown drivers I knew, John Rinker and Lee Sutter.
Lee won the MOD 50 class with a three blade on his QUICKSILVER gearcase. This three blade was made by splitting two blade props at the hub and welding them together. Lee never worked for Mercury but was always a TOP RACER from the Seattle area.
Seattle had fast boats, and great engine and propeller people. The late Jerry Walin the Evinrude driver who had the speed record of 131 MPH was from Seattle and was good friends of Lee's.
Lee had been living in California at that time and we frequently talked props and measured props (This can't be Chad posting becasue he wasn't born until August 2, 1977.)
Anyway, I asked Lee how did he figure the pitch with three blades? He said THEY JUST PUT THE BLADES ON THE same PITCH BLOCK AND WELDED THEM AND they picked up speed. I wasn't convinced, then, but thought about it.
I helped John Rinker and John ran second the first heat. I said, "John, if you'll start on the inside you can win this SE Nationals." So John starts on the inside gets to the first turn first and blows over breaking his back. Years later, as John and I were talking, I was telling him I always blamed myself for him breaking his back.
John told me, that breaking his back was the best thing that every happened to the Rinker Boat Company. I asked, "Why?" John said he could not run PRODUCTION while hurt, so he had to have an employee run the production end of the business. When John got well, he worked on DEVELOPMENT, new models, new molds... John and I are still good friends.
Back to three blades...I then saw Sutter at Beloit at the SST World Championships and asked again about two blade and three blades. He convinced me to go home and weld up some props.
By the 1977 Nationals more than 50% of the winning boats were running three blades. Later that year I welded up some two blades into four blades and they were faster yet. THE KNEELDOWN DRIVERS IN APBA STOCK VOTED FOUR BLADES OUT. THAT RULE IS STILL IN EFFECT in Stock but Mods, OPC, AND PROP still have an open propeller rule. Most Pro and Mods run either four or five blades.
At Kankakee, Illinois, 1998 or 1999 the SST 120 class had about 20 boats. The water was like glass and Gary Pugh of Pugh Boats works, just beat the field by half a lap in a five lap race. I thought, well GLASS WATER and only 10 boats in the final, Gary is running a three blade. I went to watch them weight Gary's boat after the race and to snoop at his prop scale. To my surpris, Gary's prop was a FIVE BLADE.
The fastest SST 120 RACE BOAT in America had a five blade when everyone else had a four...
I do know this, Chad Hill has been around props all his life and personally tests almost every design he sells, if his web site says something, he'd probably right.
Myself, props are still a big mystery, really. My dad used to rub my props with lipstick, and then pound on the with a big hammer and a block of lead. We frequently learned how to slow a boat down, and we seldom were able to make slow props go as fast as fast props.
I guess if it was easy, they would only make one prop....
I might add that ENGINE TORQUE may effect the number of blades. I was talking to a guy in Florida. He's run his friends four blade and it was four MPH faster than his three. He then bought the same size from SOLAS which is what he'd tested and it was 2 slower than his. Then, he tells me his friend's had been modified "JUST A LITTLE"...
You don't buy a hunting dog's brother, same for props buy the one that works.
The COOL thing about E-Bay, if you do buy the wrong prop, there are ways of selling them now days..
hwsiii
Arcadian, I agree with you that as time passes we learn much more about props and what does and doesn't work for any particular set of circumstances. I do believe the new props you designed for the duo drives and using 4 blades for each prop is an excellent innovation and should decrease prop slip and improve prop efficiency very much.
At this point in time the duo drives are definitely the transition into the future, at least for stern drives and possibly for larger outboards, as their efficiency for carrying heavy loads and diminishing prop slip is exceptional. Then possibly this is Ron,you and I are much closer in age, but I am probably older. LOL
By the way, my name is H. W. Slater and I am glad to meet you.
H
Status
