captianlake
- Joined
- Mar 5, 2012
- 3
This is a single cylinder side plug, magnito by united american bosh corp n. The head is stamped c4 and t2. It has a power shaft and a full length exhaust down to bottom end. It has two piece guard over prop. Two blade prop. The bottom end gear box is two stamped pieces bolted together with 7 or 8 bolts. The block part is stamped s1235. It is a very small engine, probably a 1.5 hp. The motor will not turn. Does anyone know what this is and what year it was made and does it have value. Thanks in advancae for the help, I'm new here.
