I recently bought a 2000 Four Winns 180 horizon with 4.3 GL Volvo SX (1.79 gear ratio) it has alum. Volvo prop 14 1/4 x 21 that looks like it was run aground there is about a 1/2" mising off of each blade. Boat is running 41 mph (GPS) at 4800 rpm Volvo recommends 4200-4600 on the GL 2bbl carb. Im looking for more pull out of the hole and more stability on plane the boat rides ok but if you trim up a hair to much it porposes like crazy I put a hydrofoil to get more lift it helped but I still want more stability. I know i want a 4 blade SS been loking at the Stiletto Bay Pro II I think I want the 22 pitch to lower the top end rpm, but Im worried i'll lose bottom end. This may sound crazy but could the 4800 rpm be from the 1/2" of prop missing from the blades? I just can't afford to buy the wrong prop to much money to throw away, and the boat is from out of town there is know Volvo dealer in the area to try a loaner prop. Any help would be appreciated. THANKS
