Re: I need help, water pump/trim
Yes you can ask why.
It stopped peeing and overheated using muffs.
I put it in a large pail of water and still no pee.. I then checked for obtruction in little hose, no obstruction i then pulled the lower unit, before taking apart pump using a hose shot water up the water intake tube an it looked like clean water was coming through everywhere it should
then with some closer inspection i did find that the housing does have some melting
Atleast i know for a fact that i need to replace it, and from now on I am staying away from the muffs and thakyou for the info in your last post. this weekend I will be sure to do that so as to make sure there is not a problem there that may have caused it to begin with...
3 weeks ago it ran on muffs just fine for bout 15 min.
thankyou RodBolt, for your knowlege and willingness share with Jamokes like myself
I have read alot of your post and they have been very helpful..
