biglurr54
- Joined
- Feb 14, 2011
- 234
I need some help building a new dock. This will be my second dock build. My first dock build(the one I’m replacing) was a few sections of scaffolding and some 2x6s for decking! It worked great for the 10 years we used it but its time for a nice dock that we can maintain and fit our boats at.
The lake is a small lake in upstate NY so I need to pull it out at the end of the year. The current scaffolding dock was too challenging to pull and set up each year so it has stayed in and then fixed each year in the spring. This was not fun. My lakefront is shallow and mucky but there is nice sand and gravel under the 10” of muck. My current dock is 48ft.
My plan for my new dock is to create two 20ft gangways out to a 16 x 24 ft floating dock at the end. My plan is to use a winch and pulley in a tree to lift the middle section of the gangway into the air, which will pull the floating deck in in the fall. The gangway will be on removable legs for stability purposes. I think I will attach pipe vertically to the end of the gangway and have the floating dock slide on the pipes. I will also chain the floating dock to anchors in a cross pattern.
I plan to make the gangway out of 3x either 2x6 or 2x8 beams and then make the decking removable. The floating dock at the end will be 16x24 and framed out of 2x8 with 2x6 joists 24” on center. I will stuff 16 barrels under the floating dock to float it.
Some questions I have:
- Is there a better way to attach the floating dock to the stationary gangway?
- Will I have issues with the floating dock breaking up the gangway from wind or waves?
- Will 2x6 cut it or will I need 2x8s for the 20ft sections? What about the floating dock? @x6 knocks the price down but if the gangway will be springy it will be worth the money for the 2x8
- Would it be better to float the gangway? I can increase the width to 4ft to make it stable but I would like everything very stable and not rock when your walking on it.
