joeycamaro
- Joined
- Jun 22, 2014
- 22
Hi guys first timer. I have a 86 Johnson 90hp, j90tlcdc vro it's leaking gear oil from the prop shaft. It's leaking bad enough that when I tilt the lower prop down it starts dripping out. I see the bolts on the bottom of the carrier, and I'm assuming I need a puller to get it out, but I'm not sure if I have to remove anything else, or how to reinstall the carrier and what seals to replace. I'm having trouble finding a service manual, and I'm considering just taking the lower to a mechanic. I appreciate any advice. Oh, and for some reason my gear oil is dark blue, I've never seen that before. I'm not sure what kind of oil that is.
