i need help
tylor2009
ok guys my boat is still bogging down an dieing after u run it for like 2 min or so, i have replaced the fuel pump, fuel lines, all lines from pump, filters, plugs, wires, cleaned the tank, fresh gas with sea foam, but she is still dieing on me, what eles could it be
danond
Re: i need help
Something stuck in the exhaust path, the carb is out of adjustment, the float bowl needle is sticking, then fuel pump is going bad....? The list can be pretty long, but I'd start with the carb.
When was it last rebuilt?
tylor2009
Re: i need help
the fuel pump is brand new put it on today, carb wise i dont know i just recent got the boat, the people told me all it needed was freeze plug so i had it replaced, no damage was done to the block is wat the boat repair guy said
cooter2506
Re: i need help
Do a compression test on it and post results.
