Hello I need help last summer I was launching boat into water when backing up. I made a few circles and seemed fine seeing as my prop hit something coming of of trailer. Well five min out the motor went to high idle and stoped moving. got back home hooked up water hose and fired it up no water flow prop wasn't turning,put new used prop on and srill nothing,running high temp too...no water flow I know.I took lower unit off to look now should I beable to turn prop shaft and shouldn't the other shaft sticking out of lower unit turn like one? And also when I took the first prop off I had rather large pieces of rubber in bottom of unit just laing there, I'm working on lower unit 140 mercruiser.someone point me the right way please I'm lost....
