Re: I need Help!
Sounds like a nice boat. However I agree with John_S. It may be a great vessel but boats this old and in sea worthy shape are far and few between.
As far as the enginedying while attempting to shift into gear, it may be the lower shift cable. When they go bad, that is a symptom of the problem. It binds the S/I switch and kills the engine.
I had a bad lower shift cable only to find out that the shift interupt switch wire was cut by the PO as well. After reading some posts, it made perfect sense to look at that. Also, if the SI wire is cut or the switch is flaky, the boat is very hard to put into neutral. Search on "Shift Interrupt" and you can find some useful information. You can aslo look into the stickys in the adult section. Yo will need to know the S/N of your drive.
I have replaced the cable. (My first one). You will have to remove the lower unit to do the cable swap. It took about two hours to do it and rewired the interrupt switch wire. I hope to test my fix tonight. (Neutral from FWD)
I hope I didn't confuse you... Being new to I/O creates quite a learning curve.
Good Luck and Happy boating!!!
